1999 Jeep Cherokee Jeep won't start, fule pump or battery?
MAYGIRL181
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 101,000 MILES
I have had my 99 Cherokee Sport for about 18 months, and it has always taken 2 cranks to get it started (unless car was just shut off, then it cranks right over) I noticed yesterday when starting it it sounded like the battery was going dead, and sure enough this morning it wouldn't start at all. Tried to jump it several times, finally got it started but unless I had my foot on the accelerator it would die again. My dad actually had to manually engaged the accelerator under the hood to get it to start also. So it won't idle after being started, and tryign to jump it didn't help either. Could this be just a severely dead battery or could it be related to the fuel pump somehow, or maybe related to me having to always crank it 2 times to get it started? We had it checked over by a very honest mechanic & he couldn't find a problem to explain having to crank it twice. I don't know how old the battery is either, was in jeep when purchased.
Any ideas would be great.
Thursday, April 2nd, 2009 AT 1:27 PM
JDL
  • 16,098 POSTS
Hello, make sure the battery has a full charge, the cables/wires are all clean and tight on both ends.
Check fuel pressure and idle air system. Can you check codes? If you can get it running, some of the national brand autostores will check codes for free.
Thursday, April 2nd, 2009 AT 2:08 PM
