Brake lights not working?
TERRI DEKKER
  • 1989 JEEP CHEROKEE
  • 4.0L
  • 6 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
Blinker arm broke off in steering column no blinkers work. Manually use blinkers activates the wipers on there own. Also, brake lights do not work when push down brake pedal.
Thursday, November 12th, 2020 AT 12:28 PM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
That is usually called the "multi-switch" and is readily available at your local auto parts store and is around $100.00. If you feel confident in doing the repairs yourself I can give you diagrams and how to steps. You will need a few specialty tools (steering wheel puller, lock plate removal tool). It involves removing the steering wheel and some steering column trim piece removal. I have attached a link showing what is involved removing the steering wheel. Hope this helps and feel free to ask any questions. Thanks for using 2carPros.
Danny-
https://www.2carpros.com/articles/steering-wheel-removal
