1994 Jeep Cherokee brake lights
ROBINTROTTER2004
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 81,000 MILES
My brake lights do not come on when I step on the brake. I tested the bulbs and they are good and I also checked the fuse and it is good. Could it be the brake light switch? How do I test it?
Monday, September 28th, 2009 AT 1:34 PM
Follow the brake pedal arm till it meets up with the brake support bracket-disconnect the wiring connector and put a jumper on it did the brake light come if so adjust or replace the switch-If not check the power side back to the fuse F13 20amp if okay -You have an open on the white and tan wire going to the lights from the brake switch.
https://www.2carpros.com/forum/automotive_pictures/12900_brake_11.jpg
Monday, September 28th, 2009 AT 1:54 PM
