1988 Jeep Cherokee Front End Shimmy
BECCA1234
Ok so i have a 1988 jeep cherokee and it has a small lift. i sometimes take it off roading and it does fine. lately, i have taken it offroading and i'll get on the main road and it starts to shake. if i go over a certain speed it'll start rattling terribly. it will do this randomly. the entire front end will be shaking. i will put it in neutral and slow down to about 10 miles an hour and it will stop shaking. i haven't gone to get it checked out yet. does anybody know what could be possibly be wrong?
Aug 27, 2006 at 1:25 PM
DEMEARSJR
  • 110 POSTS
What do you consider a small lift?
Sep 2, 2006 at 7:07 PM
BECCA1234
its a 3in. lift and i was told it could be some type of bar attached to the axel. i'm not sure though.
Sep 3, 2006 at 5:21 AM
DEMEARSJR
  • 110 POSTS
Usually when you lift a vehicle 3 inches or more it changes the angle of the driveshaft enough so that it can't turn properly causing the vehicle to shake. Most lift kits give you a piece to install between the transfer case and the frame to lower it to eliminate the vibrations.
Sep 3, 2006 at 1:52 PM
DEMEARSJR
  • 110 POSTS
Did you find the cause of your shake?
Sep 14, 2006 at 5:41 PM
DEMEARSJR
  • 110 POSTS
Check your steering damper.
Oct 6, 2006 at 3:36 PM
BECCA1234
well i have talked to some of my friends and they thought that i might need an adjustable track bar. i have changed all four u- joint things and it still continues.
Nov 17, 2006 at 4:56 AM
Suggested Repair
After a 3-inch lift, check the driveshaft angle and install a transfer-case drop between the transfer case and frame if the kit requires it. Also inspect the steering damper and track bar; the U-joints were already replaced without fixing the shake.
Conversation Summary
A 1988 Jeep Cherokee with a 3-inch lift shakes badly at the front end at certain road speeds after off-roading, then stops when slowed to about 10 mph in neutral. The owner replaced all four U-joints and friends suggested an adjustable track bar. The expert said a lift of 3 inches or more can change the driveshaft angle enough to cause vibration and that many kits include a transfer-case drop to correct it, and also advised checking the steering damper.
