1993 Jeep Cherokee Front End Shake
RWD3624
I have a 93 cherokee 2wd 6c 4.0l. The problem with this vehicle occurs at relatively high speeds (in excess of 50mph). When a single tire of the front end hits a pothole or expansion joint awkwardly in the road the front starts shaking and hopping violently along with the steering column vibrating. Once this occurs I have to slow down and pull off the road and then back on. I have recently replaced the tires and steering stabilizer but to no avail the problem persists. I have also had a few mechanics take a look at it. I have been told everything looks fine and tight. One thing to note is this vehicle has extensive exposure to salt and is pretty rusty underneath. Possible metal fatigue? I have also noticed the problem seems to not occur when the tires are fully inflated, but this could be my imagination.
Any ideas? All serious replies appreciated.
Dec 18, 2006 at 11:31 AM
SERVICE WRITER
  • 9,123 POSTS
Try a heavy duty steering stabilzer. This is a shock absorber looking part the goes side to side on your steering. Moog make one, but it has to be a heavy duty one or it won't help. Check the connections on each end of the stabilzer before you buy one. Two style were made for the jeep grand cherokee.
Dec 23, 2006 at 2:09 PM
Suggested Repair
Check both ends of the steering stabilizer for secure connections, then install a heavy-duty steering stabilizer such as a Moog unit, matching the correct style for the Jeep.
Conversation Summary
A 1993 Jeep Cherokee 2WD with a 4.0L shakes and hops violently at speeds over 50 mph after a front tire hits a pothole or expansion joint, with vibration in the steering column. New tires and a steering stabilizer did not fix it, and mechanics found the front end tight despite rust underneath. The expert recommends verifying the stabilizer connections and installing a heavy-duty steering stabilizer.
