1995 Jeep Cherokee Aggressive Wobbling
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
HARRIS_JR
After hearing a slight clanking sound, the front end wobbles and shakes whenever I take any kind of left turn (10 degrees or more) at higher speeds (50+ MPH.) It also happens sometimes over uneven roads like bridges or overpasses at higher speeds. Perfectly fine while straight or taking right-hand turns.
Jul 21, 2010 at 3:22 PM
KHLOW2008
  • 41,812 POSTS
Hi harris_jr,
Thank you for the donation.
I believe this is known as the "Death Wobble " and is a known fault that is rather difficult to overcome at times. If you google your search on " Death Wobble" you would find a lot of such atricles.
Hope it is helpful.
Jul 22, 2010 at 12:58 AM
HARRIS_JR
Thanks for all your help! I looked and found that the sway bar had broken at the screw near the top and just replaced both sides and the problems fixed!
Jul 25, 2010 at 9:14 AM
KHLOW2008
  • 41,812 POSTS
Glad to know you have fixed the problem.
Thank you for using 2carpros and have a nice day.
Jul 25, 2010 at 9:24 AM
