1990 Jeep Cherokee Wheels Lock on Turns
TLADAMS
i have a 1990 jeep cherokee just purchased and i noticed today when i make a sharp left or right turnthe front wheels seem to lock upand slide!
straighten the wheel and it goes fine...any help out there?
May 1, 2006 at 6:56 AM
LOSONE
  • 1,616 POSTS
Is it two or 4 wheel drive??
May 1, 2006 at 7:06 AM
TLADAMS
[quote= "losone"]Is it two or 4 wheel drive??[/quote] it is 4 wheel drive
May 2, 2006 at 12:29 AM
LOSONE
  • 1,616 POSTS
You may have a defective CV joint on that side that causes the wheels to lock. Oddly it could be the opposite side that is causing the problem. You can take a bar and position it so you can check for vertical slack in the joints. Do it on both sides with the wheels straight ahead. There shouldn't be over 1/4 inch of vertical slack.
It is not a safe situation because they may start to wear and lock on a small turn. Check it out and let me know. Good luck
May 2, 2006 at 1:56 AM
Suggested Repair
Inspect both front CV joints for vertical play with the wheels straight ahead; more than 1/4 inch of slack indicates a defective joint that can lock the wheels in a turn and is unsafe.
Conversation Summary
The owner of a 1990 Jeep Cherokee 4WD says the front wheels lock and slide during sharp left or right turns but drive normally when the steering is straightened. The expert suggests a defective CV joint, possibly on the opposite side, and recommends checking both sides for excessive vertical slack.
