Jeep engine backfires when trying to start
70,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
BISHIE
My vehicle cant start. It back fires through the throttlebody when turning the engine.initially it showed fault code for intermittent CPK ,stuck transmission shift solenoid and injector 1 misfire.I had it filled with gas to the bream as I was making a long trip and that's when all hell broke lose.It had no power,and was running as if its cutting fuel (pulsating) and it also increased fuel consumption significantly.It finally died as I was about to reach home.I put in a set of upgraded (4 hole) fuel injectors,changed CPK and Camshaft sensor, no difference.can u please help me to trouble shoot the problem.
Dec 10, 2013 at 9:02 PM
  • 110,251 POSTS
Is the check engine light on? Have you checked fuel pump pressure?
Jan 5, 2020 at 11:49 AM
BISHIE
This is a follow up question to the one I asked.
I just remembered that at some point the jeep threw in these codes:
P0340, P1765, P1391, P0531, P0761 and C214C.
This codes then disappeared except for P1391 and P0301 showed up. I also recall that before it shut off, the MIL light flashed for some time. Presently the codes which are persistent when cranking are P0761 and C214C.
I tried the quick start spray trick with no success. I have read threads about catalytic converter and camshaft target wheel. can one of them or both cause it to backfire through the throttle body? Please help. I am at my wits end with this car.
