2000 Jaguar S-Type Stalls in Drive
FSTRANGER302
  • 117 POSTS
i have 2000 s type. rebuilt the trans and has new torque converter. put it in reverse and it is fine put it in drive and the car stalls out what can this be
Sep 20, 2006 at 2:36 PM
FSTRANGER302
  • 117 POSTS
[quote:618bf8753c="fstranger302"]i have 2000 s type. rebuilt the trans and has new torque converter. put it in reverse and it is fine put it in drive and the car stalls out what can this be[/quote:618bf8753c]figured it out the trans part store gave me the wrong gasket for the valve body works fine now
Nov 14, 2006 at 2:10 PM
Suggested Repair
Install the correct valve body gasket. The wrong gasket supplied with the rebuilt transmission caused the engine to stall in Drive while Reverse worked normally.
Conversation Summary
The owner of a 2000 Jaguar S-Type rebuilt the transmission and installed a new torque converter. Reverse worked, but selecting Drive stalled the engine. They later found the parts store had supplied the wrong valve body gasket, and the correct gasket fixed the stall.
