2000 Jaguar S-Type Window Stops Short
2000S-TYPE
My driver side window works well except that when it gets to the rubber moulding on the window frame it stops and doesn't go up anymore. I did notice that when I push it up with my hands the glass moves from side to side, can someone help? Thanks
Apr 6, 2006 at 4:50 AM
2CARPRO JACK
  • 11,533 POSTS
sounds like the guide or regulator are having a problem. Be careful the door panel has to come off and you dont want to mar it
Apr 6, 2006 at 10:07 AM
2000S-TYPE
I took the panel off, no problem there; however upon inspecting the area everything seems fine except for a few pieces of white plastic I found at the bottom of the door. I match them up and they seem to be some sort of small bracket. Also after putting the door panel back it seems the window is going up sluggish. Another thing, I see that everyone always mentions the regulator when talking about power windows, are they referring to the motor?
Apr 7, 2006 at 1:03 AM
FSTRANGER302
  • 117 POSTS
hello what you need to fix this problem is a window regulator. the plastic you foundis for the guides.
pretty soon if not already the regulator will stop all together going up and down
Sep 20, 2006 at 1:12 PM
Suggested Repair
Replace the window regulator and the broken plastic guide clips. The white plastic pieces found in the door are guide parts; a failing regulator explains the incomplete travel and sluggish movement.
Conversation Summary
The owner of a 2000 Jaguar S-Type reported the driver window stops at the rubber moulding and the glass shifts side to side. After removing the door panel, they found small white plastic pieces at the bottom of the door and later noticed sluggish upward travel. Experts said the pieces are guide parts and that the window regulator is failing and should be replaced before it stops working completely.
