passenger side window will roll down but not back up?
95,000 MILES • V12 • 2WD • AUTOMATIC
ISLANDHIPPIE
My passenger side window will roll down but not back up. Does this sound like just a loose connection somewhere or could it be inside the window motor itself? Also is there a way to manually get the window to roll up? Thanks a lot fellas!
Dec 16, 2007 at 3:15 AM
DAVE H
  • 13,383 POSTS
remove and clean or replace the switch
Jan 5, 2010 at 9:45 PM
ISLANDHIPPIE
I went back and did some further investigation and found that the switch was not making proper contact internally. I took it apart, cleaned all the small parts, and added fresh grease. I reinstalled the switch and it works perfectly. Thanks anyway and hope I have a harder question for you next time.
Nov 6, 2010 at 6:18 AM
  • 55,649 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Nov 6, 2024 at 5:19 AM
