2000 Jaguar S-Type Hot Shift Delay
JAGUAR
PETER987
Hi my name is Peter I own a Jaguar S type 4.0 year 2000 98000 miles.
When the car is hot and I shift from park to drive the transmission will not always engage if I shift to 4 it will engage, then I shift to drive and it's ok.
The owners manual says the transmission is a sealed unit no fluid levels to check for the lifetime of the unit what do you suppose is going on?
Thanks,
Peter
Jun 18, 2007 at 6:26 AM
DAVE H
  • 13,383 POSTS
Powertrain Control Module
The operation of the transmission is controlled by the powertrain control module. Many input sensors provide information to the powertrain control module. The powertrain control module then controls the actuators which determine transmission operation.
the vehicle needs to be plugged into a diagnostic computer to locate the cause of the fault !
Oct 25, 2009 at 2:27 AM
Suggested Repair
Have the vehicle scanned with a diagnostic computer so the powertrain control module and related transmission sensors and actuators can be checked for the cause of the delayed engagement.
Conversation Summary
The owner of a 2000 Jaguar S-Type 4.0 with 98,000 miles reports that when the car is hot, shifting from Park to Drive does not always engage. Selecting 4 engages the transmission, after which Drive works normally. The owner notes the manual describes the transmission as a sealed unit with no fluid level to check. The expert explains that transmission operation is controlled by the powertrain control module using input sensors and actuators, and recommends connecting a diagnostic computer to locate the fault.
