1994 Jaguar XJS Stalls After Stops
PLAYAJW
I own a 1994 XJS 4.0 litre 6cylinder wih 78,000 miles. It is a mint condition car and truly a joy to drive. However, it tends to stall following stopping at a stop sign or light. It sputters and dies. Ill restart it and the same thing happens until I can get it to accelerate go and then it smooths out often with no more problems until it sits for a period of time and then drive it again.
I am assuming that my Mass Air Flow Sensor is the culprit but I would like to be sure before I purchase one to swap out.
Any help would be appreciated.
Thanks
Jun 29, 2007 at 3:05 PM
FSTRANGER302
  • 117 POSTS
[quote:6783538b36="playajw"]Hi,
Thanks[/quote:6783538b36]
hello, have you checked the throttle body to see if it is dirty. with the car cold check the throttle pot, were the cable conects to the throtlle body. if it sticks when you are tring to move it . it will need to be cleaned with some cleaner. also if you think you have a maf sensor problem, you can unplug it and the car will still run and drive. but it will possibly turn on a check engine light. if it does just disconect the battery and it will go out. let me know if this helps.
Nov 16, 2007 at 11:19 AM
Suggested Repair
With the engine cold, inspect the throttle body and throttle position sensor where the cable connects. If the throttle sticks, clean it with throttle-body cleaner. To test the mass airflow sensor, unplug it and see whether the stalling stops; the engine should still run, though a check-engine light may appear and can be cleared by disconnecting the battery.
Conversation Summary
The owner of a 1994 Jaguar XJS 4.0 reports occasional stalling after stopping at lights or signs. The engine sputters and dies, then runs normally after it is restarted and accelerated, until the car sits again. The owner suspects the mass airflow sensor. The expert recommends checking a cold throttle body and throttle sensor for sticking and cleaning them if needed, and testing the mass airflow sensor by unplugging it.
