1993 Jaguar XJS Coolant Leak Plate
RANDYBURLESON
'93 XJS 4.0L 6CYL.
I have had problems with losing water.
I believe I have a bad head gasket or cracked head.
Anyway.. that leads me to my problem. I have been refilling the water on a daily basis and lost all of my antifreeze. So, when it got below freezing the other day a plate cracked on the back of the cylinder head and now water leaks out as fast as I can put it in.
This plate is on the back of the Cylinder head/block next to the firewall. it is about 6" or so in diameter and is bolted on. What is this part called and where can I get a replacement? How much is it?
Dec 16, 2006 at 2:29 AM
CARUNDELL
  • 602 POSTS
[quote:e3149b3828="randyburleson"]'93 XJS 4.0L 6CYL.
This plate is on the back of the Cylinder head/block next to the firewall. it is about 6" or so in diameter and is bolted on. What is this part called and where can I get a replacement? How much is it?[/quote:e3149b3828]
Hey Randy,
Sounds like a freeze plug went. I recommend you stop just adding water as it only makes your troubles worse by causing rust/corrosion in the engine block and head!!!! Antifreeze is designed to inhibit this! as to the cost of the part I really couldn't say, but if it is a bolt up style plug I'm pretty sure only jaguar will have it.
Chris
Dec 16, 2006 at 3:25 AM
FSTRANGER302
  • 117 POSTS
the part is called a water port cover. it is on the back of the cylinder head and has 6 bolts holding it on. it also has a yellow gasket that will go between it and the block. this would be a dealer part i also have one in my garage as i am a jag mechanic hope this will help
Dec 19, 2006 at 1:21 PM
GOODSAMARITAN742
  • 12 POSTS
fstranger302....question for you ever heard of turbos being put on jags...the only jag w a factory turbo is the xjr....im buying a 1994 xj12 and wanted to put a turbo on it if it can be done w out lots of fabrication...also please let me know buy email replay if you take on other people's jags to work (of course depending on what state you are in
goodsamaritan742@comcast.net
Apr 12, 2007 at 8:05 PM
Suggested Repair
Replace the cracked rear cylinder-head water port cover (a bolted plate, also described as a freeze plug) and its yellow gasket with a Jaguar dealer part. Refill with the correct antifreeze mix rather than plain water, and have the original coolant loss checked for a possible head gasket or cracked head.
Conversation Summary
The owner of a 1993 Jaguar XJS 4.0L was losing coolant and suspected a bad head gasket or cracked head. After the system froze, a roughly 6-inch bolted plate at the rear of the cylinder head near the firewall cracked and leaked rapidly. One expert identified it as a freeze plug and warned that adding only water promotes corrosion. Another identified it as a water port cover held by six bolts with a yellow gasket, available from a Jaguar dealer. An unrelated later comment about turbocharging a different Jaguar was not answered.
