1986 Jaguar XJS air intake
1986 JAGUAR XJS
42,000 MILES • V12 • 2WD • AUTOMATIC
GREGDUCEY68
I recently purchased this car, it was in storage for approx. 5 yrs, it has a new fuel filter, I drained all of the old gas out of it, put new fuel lines and plugs in. It fires up and runs perfectly at idle. It bogs down at 3000 rpm's. The left side of the motor is sucking air perfectly. The right side of the motor is not drawing any air at all thru the inlet. Both of the exhaust pipes are blowing good at about the same pressure. The air filters are good. I checked them first thing.
Feb 17, 2008 at 1:56 AM
DAVE H
  • 13,384 POSTS
XJS MANIFOLD PRESSURE SENSOR (MPS)
Disconnect battery. Pull connector from MPS. Using an ohmmeter connect test leads between the terminals. Compare resistance readings to specifications.
If readings are not to specification, replace MPS. Reconnect MPS connector and battery.
XJS MANIFOLD PRESSURE SENSOR RESISTANCE
Terminal No.Ohms
7 & 15 85.5-94.5
8 & 10 346.5-353.5
7 or 15 & Ground 0
8 or 10 & Ground 0
Jan 5, 2010 at 10:01 PM
