I need to know how to replace the window regulator , can you give me instructions?
Jan 4, 2007 at 2:07 AM
Remove the front door window glass, detach the motor and regulator rail and outermost cable clip, disconnect the electrical connector, and remove the motor and regulator. Install in reverse, keeping the motor cable outermost, and tighten the clip to 6 N.m.
The owner asked how to replace the window regulator on a 2001 Jaguar XJS. The expert outlined front door regulator and motor removal: remove the window glass, detach the motor and regulator rail and outermost cable clip, disconnect the connector, and remove the assembly. Installation is the reverse, with the motor cable outermost and the clip tightened to 6 N.m.
