1995 Jaguar XJS Check Engine Light
DON MCMILLAN
Hello, I have a 1995 Jaguar XJS Convertible, V12 with 84K miles. Recently the fan belt broke and the engine overheated slightly. Now the check engine light is on and I would like to know which scanner tool to purchase. The car has an OBD1 sticker with an OBD2 plug on the drivers side. I could take this to the dealer, but would like to do my own work.
Sep 21, 2007 at 2:24 AM
WRENCH
  • 57 POSTS
This is the hard part you seem to be at the cross-over year '96 and on is obd2 but before that was obd1 sometimes they have the obd2 plug what you need is a obd1 compliant with a plug adapter for obd2 or a code reader that does both.
Sep 21, 2007 at 4:11 AM
Suggested Repair
Use an OBD1-compliant code reader with an OBD2 plug adapter, or a scanner that supports both OBD1 and OBD2.
Conversation Summary
The owner of a 1995 Jaguar XJS has a check engine light after a broken fan belt and slight overheating, and wants a scanner. The car has an OBD1 sticker but an OBD2-style plug. The expert says 1995 is before the OBD2 changeover and recommends an OBD1 reader with an OBD2 adapter or a code reader that does both.
