1995 Jaguar XJS Catalyst Codes
JIMBEAUX
Hi folks; thanks for the help you give.
I have a 1995 XJS - 4.0L AJ16 - 90,000 miles.
MY muffler guy says one of my cats is beginning to show early signs of blockage. I have changed the plugs, fuel filter, and had the throttle body and fuel system cleaned. I feel a random and inpersistant rough idle and my mileage is not what others get with this car. I get codes P0420 and P0430. Do I have a bad coil (there are 6 coils), a bad O2 sensor, a bad/dirty MAF, or bad injector? At running speeds, I notice no roughness or hesitation. Thanks for the advice. PS, any way to home test the items?
May 16, 2007 at 2:09 PM
FSTRANGER302
  • 117 POSTS
[quote:91d975f592="Jimbeaux"]Hi folks; thanks for the help you give.
MY muffler guy says one of my cats is beginning to show early signs of blockage. I have changed the plugs, fuel filter, and had the throttle body and fuel system cleaned. I feel a random and inpersistant rough idle and my mileage is not what others get with this car. I get codes P0420 and P0430. Do I have a bad coil (there are 6 coils), a bad O2 sensor, a bad/dirty MAF, or bad injector? At running speeds, I notice no roughness or hesitation. Thanks for the advice. PS, any way to home test the items?[/quote:91d975f592]
hello, the two codes you have are catalyst effeciency codes. the mean yes the catalyst are going bad and it is nessesary to replace.
Nov 16, 2007 at 11:14 AM
Suggested Repair
Replace the catalytic converters. Codes P0420 and P0430 indicate failing catalyst efficiency.
Conversation Summary
The owner of a 1995 Jaguar XJS 4.0L AJ16 with 90,000 miles reports intermittent rough idle, below-expected fuel mileage, and codes P0420 and P0430 after replacing plugs and the fuel filter and cleaning the throttle body and fuel system. A muffler shop noted early catalytic converter blockage. The expert states both codes are catalyst efficiency codes and that the catalytic converters are failing and should be replaced.
