1989 Jaguar XJS justs shuts off while driving
DAVEQWERTY
  • 1989 JAGUAR XJS
  • V12
  • FWD
  • 140,000 MILES
My XJ-S Covertible just shuts off intermittently while driving. No engine cough or sputter, no dash lights come on. It acts like I just reached up and turned the key off. I coast to the side of the road, put it in park and it starts right up and runs fine. Currently installing a new ignition switch to see if that solves the problem. Any thoughts on other items to look at?
http://www.2carpros.com/forum/automotive_pictures/524052_JAG_1989_1.jpg
Tuesday, May 4th, 2010 AT 2:18 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I feel that this is certainly an ignition based problem, often a faulty distributor or DFI module is the cause, often they can over heat and cut out, this is just like turning off the key, and when they cool a little they will work again, you may get a code if you get a scan done, remembering that you don't always get a fault light with all set codes.
Mark (mhpautos)
Wednesday, May 5th, 2010 AT 2:29 AM
