2000 Jaguar S-Type MIL Light
REBECCA HOWELL
I have a 2000 s-type jag. 3.0. The malfuntion indicator lamp warning light came on. What is wrong with the car? I have noticed for a while that the car doesn't have the same speed or pick up like it use to.
Jan 12, 2006 at 1:31 PM
2CARPRO JACK
  • 11,533 POSTS
The ECM isnt happy with something, have the ECM scanned for trouble codes
Jan 18, 2006 at 9:16 AM
PHILOS2ROCK
[quote:98a9b6f162="rebecca howell"]I have a 2000 s-type jag. 3.0. The malfuntion indicator lamp warning light came on. What is wrong with the car? I have noticed for a while that the car doesn't have the same speed or pick up like it use to.[/quote:98a9b6f162] :D on this type of jag usuli has a vac leak in betwing intake on the pcv sistem let me know[/b]
Jan 29, 2006 at 3:13 PM
Suggested Repair
Have the ECM scanned for trouble codes to identify the fault that illuminated the malfunction indicator lamp, then repair the confirmed fault. Reduced power may be related to that stored fault.
Conversation Summary
The owner of a 2000 Jaguar S-Type 3.0 reports the malfunction indicator lamp is on and the car has less speed and pickup than before. The expert says the ECM has detected a problem and recommends scanning it for trouble codes. Another participant speculated about a vacuum leak in the PCV system near the intake, but that was not confirmed.
