2000 Jaguar S-Type Won't Accelerate
ARRED209
i have a 2000 jaguar s-type 4.0 car was working fine until last night i started the car put it in gear but it wouldn't accelarate. and the check engine light came on.if i put the car in driver or reverse it will move just at the speed any other car would with out accelerating but when i press the gas peddle it won't do anything
May 23, 2006 at 8:20 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it could be a fuel pump or Mass Airflow Sensor
Sep 12, 2006 at 7:49 AM
FSTRANGER302
  • 117 POSTS
the car is in limp home mode when the computer sees a major problem it locks the trans into 4th gear only limp in mode. there is a hard fault in the computer. usally a throttle motor or trans fault will cause this
Sep 20, 2006 at 1:17 PM
Suggested Repair
Scan for stored fault codes. The no-acceleration symptom is consistent with limp-home mode, often caused by a throttle motor or transmission fault; also check the fuel pump and mass airflow sensor.
Conversation Summary
A 2000 Jaguar S-Type 4.0 starts and creeps in drive or reverse, but the accelerator does nothing and the check engine light is on. One expert suggested a fuel pump or mass airflow sensor problem. Another said the car is likely in limp-home mode from a hard computer fault, commonly a throttle motor or transmission fault that limits gear selection.
