2000 Jaguar xjr
2000 JAGUAR XJR
NOVAERIC4
I have a cutomers Jaguar xjr supercharged in with a trans fluid leak.It looks like it is coming from a wiring bulkhead going into the trans by the bell housing.The local dealer says that they sell no parts for this trans,just reman units.This seems exorbitant to me just to repair a slight leak caused bt a faulty o-ring.Any help that anyone can provide would be greatly appreciated.
Dec 4, 2006 at 3:00 AM
FSTRANGER302
  • 117 POSTS
this oil leak is common. but to replace the orings for the leak you would have to replace the connector. and the trans fluid has to be set a special way using atrans temp to set. that would have to be done at the dealer. hope this helps
Dec 19, 2006 at 1:25 PM
