1998 Jaguar XJ Hard Start
1998 ALL OTHER MAKES ALL OTHER MODELS
SKYDEN
I have a 1998 XJR with only 60,000 miles on it, however, a couple time after I picked someone up at the airport or filled up at the gas station, I can't seem to start the car (it starts, but takes a long time while it struggles to start), as you can imagine, it is embarrassing to not start in such a beautiful and luxurious car. I have been told this might be a nikasil liner problem, or a throttle body problem (but this was cleaned at 45,000miles), or spark plugs, I would like to know what would probably be my best bet before plunging more money into this thing....
Nov 12, 2006 at 2:51 AM
FSTRANGER302
  • 117 POSTS
it is possible that the nikasil is the problem but not likly. it was a issue but i diid not see to many super charged motors with nikasil go bad. it is possible and i think this is the problem that the secondary timing chain or chains let loose. causing the timing on the camshafts to be off. this is a very common problem with the older cars. i work for a jaguar dealer and this is what i have seen by your description. any other questions feel free to email me at thedeerhunter30
@hotmail.com
Nov 14, 2006 at 1:46 PM
Suggested Repair
Have the secondary timing chain or chains inspected and corrected if loose, since that can throw camshaft timing off and cause hard starting. Nikasil liner failure is less likely on this supercharged engine, and the throttle body was already cleaned.
Conversation Summary
The owner of a 1998 Jaguar XJR with 60,000 miles reports slow, struggling starts after short stops such as airport pickups or fueling. Possible causes mentioned include Nikasil liners, the throttle body, or spark plugs. A Jaguar dealer technician says Nikasil failure is uncommon on supercharged engines and instead points to loose secondary timing chains throwing off camshaft timing, a common issue on these older cars.
