2004 Jauguar XJ8 20,000 miles
2004 ALL OTHER MAKES ALL OTHER MODELS
JULIA SENSENICH
The problem we have is the following, the air ride will not lift the car up. The air ride isn't working. The car has been hit in the rear end. Please advise as to how we can get the air ride to work so the car can be moved. Thank You!
Sinerely,
Julia
Jun 2, 2006 at 5:13 PM
2CARPRO JACK
  • 11,533 POSTS
check for a air ride power switch in the trunk.It may be turned off due to a leak or bag problem
Sep 12, 2006 at 7:47 AM
FSTRANGER302
  • 117 POSTS
you need to see it the compressor is working when the car is running, the air suspension resivoir is in the trunk, itmay have been damaged. use some kind of soapy water to check for leaks. the car has no switch to turn off the air suspension. it has amodule that will raise and lower suspension even after the car is off.
if you lift the car. make sure you lift evenly or with the key off. this will make suspension module confused. disconect battery for 5 minutes and retry
Sep 20, 2006 at 1:36 PM
