1995 Lincoln Continental Air Ride Compressor Fix
1995 ALL OTHER MAKES ALL OTHER MODELS
ALAJIM
does anyone know where the compressor relay is located in the car? The compressor runs when I connect power directly to it but doesn't ever get acuated automatically. The "Check Ride Control" message is on in the car. The 20 amp fuse under the hood is fine. Any ideas?
Mar 16, 2006 at 6:31 AM
DAN CHOATE
the ansewer to your question is there is another relay above your right cooling fan it kinda looks like a small amp let me knows if it was the problem
Mar 29, 2006 at 4:06 PM
ALAJIM
Thanks I found it and replaced it. the compressor is running again but I don't think that the output is strong enough. it runs for a while and is lifting the car but then the system stops and the ride control warning comes back on. Is there a rebuild kit or something to improve the performance of the compressor or should I just replace it?
Mar 30, 2006 at 1:08 AM
PEPPERMRJ
  • 1,158 POSTS
There is no kit that I know off. Do a google for lincoln air ride and you will come up with several sites that sell compressors,new and rebuilt.
Good luck and let us know. :)
Mar 30, 2006 at 10:38 AM
Suggested Repair
No air-ride compressor rebuild kit is known. Replace the compressor with a new or rebuilt Lincoln air-ride unit from a specialty supplier.
Conversation Summary
On a 1995 Continental, the air-ride compressor would not run automatically and the Check Ride Control warning was on, though the under-hood 20-amp fuse was good and the compressor ran when powered directly. Another user pointed to a relay above the right cooling fan; after that relay was replaced, the compressor ran and raised the car, then stopped and the warning returned. The owner asked about a rebuild kit for weak compressor output. The expert said no kit was known and recommended buying a new or rebuilt compressor from Lincoln air-ride suppliers.
