1997 Lincoln Continental Ride Control Sag
FORD
SANDOVAL
1997 Lincoln Continental indicates check ride control. The rear of the car passenger side is noticeably now lower then the driver side. What should i expect to repair this problem?
Jan 22, 2006 at 3:19 PM
NAPAGUY
  • 14 POSTS
Big Bucks if you have to replace a computer controlled strut....that's if the part is available yet....Ford stopped making replacement parts for some of these systems, depends on the age. Napa, however has a standard strut/shock system that replaces the whole ride control system.......I've sold several , and the feedback I get is that you can't tell the differance in the ride. O the other hand, it could be as simple as a broken line :lol:
Jan 23, 2006 at 10:38 AM
  • 55,783 POSTS
Sounds like you have an air bag that has a hole in it.
Jan 23, 2006 at 10:39 AM
SC1 RACING
  • 117 POSTS
i found a site that has very cheap air suspension parts, and hard to find parts. a liftime warranty air bag was only 79.00.
i will post in the morning the site. all the info is at my house right now.
Jan 25, 2006 at 1:41 AM
Suggested Repair
Inspect the rear passenger air suspension bag for a hole or leak and replace it if damaged. A second expert said replacement air bags were available inexpensively with a lifetime warranty, but did not post the supplier.
Conversation Summary
A 1997 Lincoln Continental owner reported a check ride control warning and a lower passenger-side rear. A non-expert reply said a computer-controlled strut could be costly or unavailable, mentioned a conventional strut conversion, and also suggested a possible broken line. An expert said the symptom sounds like an air bag with a hole. Another expert said inexpensive air-suspension parts were available but never posted the source.
