bounce?
LINCOLN CONTINENTAL
DREANON
i just got a new to me 1995 lincoln continental with 84,000mmiles. i am learning a few things as i am working around the car. my car bounces with everything that i run over, what is the problem there?
Aug 24, 2007 at 3:27 PM
BRUCE HUNT
  • 3,754 POSTS
Did they base their information or recommendation on a pressure check or did they give you their best guess? There are sensors like the crank or cam sensors that can cause similar problems. If the fuel pressure is low you know it is fuel related.
Jun 6, 2007 at 1:50 AM
THANYC12
the looked at it and basically it was a best guest they didnt run any tests on it
Jun 6, 2007 at 4:52 AM
RALEIGH0
  • 6 POSTS
I've also had an ongoing problem with fuel pumps on my 1988 Integra overheating in the really hot weather (especially with the air conditioning on). The ENGINE QUITS AND WON'T START UNTIL I LET IT COOL OFF. Sometimes there is a loud hissing or whistle coming from in front of the left rear wheel well where the pump is located and the pump itself is way too hot to touch. It gets worse and worse until I have to replace the pump. Sounds like you may have the same problem. I know it gave me fits until I figured it out.
I know they finally started putting the fuel pump inside the gas tank to keep it cool!
Jul 21, 2007 at 6:03 PM
ALLBROWN
  • 27 POSTS
Your suspension is go'n bad. ck ur shocks , air compressor & relay.
Aug 30, 2007 at 6:35 AM
