1998 Jaguar XJ Timing Not Adjustable
might not be adjustable. just set to 1 cyl and the computer does it all
Sep 12, 2006 at 7:50 AM
it is not adjustable.
timing chains are set in place by special tools holding the crank and camshafts into proper timing then you would torque all gears on timing chains to spec
Sep 20, 2006 at 1:18 PM
hi jaguar dealer technician here timming is not adjustable special tools are required to hold cams down you have to turn crank to cyl 1 and remove crank sensor from flywheel and install special tool in place to lock it in then go up top and lock cam tools down in place you would only be doing this if you are replacing chains,tensioners or removing heads
Jul 11, 2008 at 6:48 PM
Suggested Repair
Ignition timing is not adjustable on this engine; the computer controls it. Timing chains are positioned with special tools that lock the crank at cylinder 1 (crank sensor removed and a locking tool installed at the flywheel) and lock the camshafts, then the chain gears are torqued to specification. This procedure is only needed when replacing chains or tensioners or removing the heads.
Conversation Summary
The owner asked how to set timing on a 1998 Jaguar XJR because no timing marks were visible. Experts agreed timing is not adjustable and is controlled by the computer. A dealer technician explained that special tools lock the crank at cylinder 1 and hold the cams in place, and that this is done only when replacing chains or tensioners or removing the heads.
