2000 Jaguar XJR Trans Fluid Leak
NOVAERIC4
I have a cutomers Jaguar xjr supercharged in with a trans fluid leak.It looks like it is coming from a wiring bulkhead going into the trans by the bell housing.The local dealer says that they sell no parts for this trans,just reman units.This seems exorbitant to me just to repair a slight leak caused bt a faulty o-ring.Any help that anyone can provide would be greatly appreciated.
Dec 4, 2006 at 3:00 AM
FSTRANGER302
  • 117 POSTS
this oil leak is common. but to replace the orings for the leak you would have to replace the connector. and the trans fluid has to be set a special way using atrans temp to set. that would have to be done at the dealer. hope this helps
Dec 19, 2006 at 1:25 PM
Suggested Repair
This leak is common at the transmission wiring bulkhead. The o-rings are not sold separately; the connector must be replaced. Afterward, set the transmission fluid level using the temperature-based procedure, which typically must be done at a dealer.
Conversation Summary
A 2000 Jaguar XJR has a transmission fluid leak at the wiring bulkhead near the bell housing. The dealer offered only a remanufactured transmission, not individual parts. An expert said the leak is common, the connector must be replaced to renew the o-rings, and the fluid level must be set by transmission temperature at a dealer.
