This is 16 things to check I would look towards #3 first
1 Inspect Fuel Filter Clogged or dirty fuel filter
2 Inspect Air Filter Restricted or clogged air filter.
3 Inspect Fuel Injector Cold Start Valve Faulty cold start valve or circuit.
4 Inspect Battery Damaged or faulty battery and/or connections.
5 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
6 Inspect Spark Plug Fouled, damaged or broken spark plug(s).
7 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit.
8 Inspect PCV Valve Plugged or damaged pcv valve.
9 Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit.
10 Inspect Air Charge Sensor Damaged or faulty air charge sensor or air charge sensor circuit.
11 Inspect Air Cleaner Temperature Sensor Damaged or faulty air cleaner temperature sensor or air cleaner temperature sensor circuit.
12 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit.
13 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector.
14 Inspect MAP Sensor Improperly connected or faulty m.A.P. Sensor.
15 Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor.
16 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system.
Friday, October 24th, 2008 AT 6:42 PM
