1994 Jaguar XJ6 No start
TNTCARCARE
  • 1994 JAGUAR XJ6
Engine Performance problem
1994 Jaguar XJ6 6 cyl Automatic 73,000 miles
Is there a common problem with the XJ6's, no start issues?
The car would start and run just fine, until recently. Fuel pump works, fuel pump relay is fine, spark is there. New fuel filter, spark plugs, cap, rotor, oil and filter. Battery is completely charged.
Sat for 2 days, and it wouldnt start. Next day, tried it again, it started, but it was weak and it died almost right away. Tried to start it again, but it wouldnt. Any ideas or suggestions are appreciated. Thank You!
TNT
Thursday, May 1st, 2008 AT 5:59 PM
JAMES W.
  • 2,394 POSTS
Sounds like you have covered most of the bases. What you need to do is try to narrow down your problem, ie when the "no start" condition exists, see what you are missing, fuel, spark or both. This will help pinpoint the problem. It may be the crankshaft position sensor. Just a thought. Please advise.
Tuesday, October 7th, 2008 AT 3:15 PM
