1994 Jaguar XJ6 starting problem
TOMMYGAM
  • 1994 JAGUAR XJ6
  • 6 CYL
  • 193,000 MILES
My 1994 Jaguar XJ6 will not start in the mornings or after sitting for a few hours. If I drive it and stop for a short time it will start right up. But after a few hours of not running it is so hard to start. It cranks fine and could take 5-9 tries before it starts. But if I drive it and stop for a short while it will start again fine on the 1st try. I had the fuel pump and fuel pressure regulater replaced and this didn't solve the problem. It also had a full tune up dun, wires plugs cap and toter. Still hard to start. One other thing is happening, when the car does start it makes a bad niose almost like a belt but its not a belt. I was told it was a air pump? Could that have anything to do with the hard starting problem? The dealer doesn't know what else to do, can you help?
Sunday, August 9th, 2009 AT 7:52 PM
DAVE H
  • 13,384 POSTS
Cranking Enrichment (4.0L)
This coolant temperature-based enrichment provides an appropriate amount of fuel when starter motor is activated. Cranking enrichment is achieved by increasing injector operating frequency (injector on time) from one pulse to 3 pulses per crankshaft revolution. Cranking enrichment ends when engine speed reaches 250 RPM at coolant temperature more than 107 °F (42 °C), or 500 RPM at coolant temperature less than 107 °F (42 °C).
Sunday, October 25th, 2009 AT 8:17 AM
