1994 Jaguar XJ6 Won't start at times
PAPASMURFSD
  • 1994 JAGUAR XJ6
  • 6 CYL
  • 16,900 MILES
Seems like the battery is draining overnight, as some times, it won't start. Possibly a short or fuse?
I am not a mechanic and it was fine I have a new battery just a little over 3 months old, New Cables, and new stand. Then all o0f sudden it won't start?
Please help with ideas or suggestiongs,
Thanks, Richard, papasmurfsd
San Diego, CA
Saturday, March 7th, 2009 AT 12:03 PM
JAMES W.
  • 2,394 POSTS
With key off, remove negative cable from battery. Check for 12 volt, full voltage, draw between the negative battery post and the negative battery cable with an incandescent test light. If light is on "full bright", start pulling fuses until test light goes dim keeping in order so they go back in the same space. The circuit that makes the light go dim is the one that is killing your battery. Then, reinstall the fuses one at a time. If the test light goes back to and stays bright, you've found another full draw circuit to check out.
Monday, March 9th, 2009 AT 5:48 PM
