I didn't mean the pressure was good I meant have a pro pressure check for a head gasket leak. It may be putting compression into cooling system causing your problem. Or see if your bottom rad hose is sucking together when you stomp on it if it is replace it.
SPONSORED LINKS
Monday, June 8th, 2020 AT 12:57 PM
(Merged)
