2004 Jaguar S-Type Starter Problem
2004 JAGUAR S-TYPE
SALTSHEIKH
2004 Jaguar S-Type V8 Automatic
So my car makes the starting sound but it wont click over so i can drive it. I asked Advance Auto Parts what the problem could be and they thought it would be a bad starter. Do you think that it is in need of a replacement starter? It is not the battery, I already checked that. If it is the starter, could I change it by myself? If so, how would I go about doing so? Where will I find the starter to change it? Thank you
Feb 21, 2010 at 6:16 AM
DAVE H
  • 13,384 POSTS
Starter Motor - Removal and Installation (2.5L/3.0L/4.2L)
All vehicles
Disconnect the battery ground cable.
Remove the air deflector.
Disconnect the engine ground cable.
Vehicles fitted with 4.2L engine
Remove the starter motor positive cable cover.
Detach the starter motor positive cable.
Remove the starter motor.
Remove the starter motor retaining bolts.
Vehicles fitted with 2.5L or 3.0L engine
Detach the starter motor positive cables.
Feb 24, 2010 at 11:23 AM
