Isuzu Trooper Stalls When It Snows
ISUZU
DANONTHEIOM
Hi
Difficult problem. My 2.8 TD trooper runs like a dream, start easily when hot or cold...except when it snows! then runs for about 40 seconds and then seems starved of fuel? Cannot figure this out as it runs well when its a lot colder...just when it snows it seems to stop? Hope you can help spread some light on this matter.
Danontheiom
May 14, 2006 at 11:11 PM
BEANS62584
You can try dry gas, might be a problem with gas tank just gunking up with the right temp at 32 deg when it snows, due to humidity.
May 16, 2006 at 11:35 AM
JOUGH626
  • 55 POSTS
Replace your fuel filter, as water can build up inside of it. New, after adding a bottle of Gas Treatment,a bottle of Dry Gas and topping your tank off as much as you can, replace your gas cap. It's only about 6-10 and it will help seal your tank from the outside air. I hope this helps.
Jun 22, 2006 at 2:11 PM
Suggested Repair
Replace the fuel filter, since water can collect in it. Add fuel treatment and dry gas, fill the tank, and replace the gas cap to seal out outside air.
Conversation Summary
The owner of an Isuzu Trooper 2.8 TD says it starts and runs well hot or cold, but after about 40 seconds it seems starved of fuel only when it snows. A reply suggested moisture or tank contamination near freezing. The expert advised replacing the fuel filter, adding fuel treatment and dry gas, filling the tank, and replacing the gas cap.
