1989 Isuzu Trooper Stalls After Start
1989 ISUZU
MCSEMANN
I recently purchased an 1989 trooper that has been sitting for a few years. I replaced the fuel pump and the enginge starts fine now, but it only stays running for a few seconds. If I shut off the ignition and restart it runs fine again for only a few seconds. If I hit the throttle it will rev up, but it eventually falls on its face again. Would injectors cause this problem? It definately seems like it is a fuel issue, but I need some suggestions,please.
Thanks
Paul
Jan 18, 2006 at 1:03 PM
2CARPRO JACK
  • 11,533 POSTS
might be the MAF sensor. Check for cracks in the boot between the MAF and the engine
Feb 10, 2006 at 4:51 AM
Suggested Repair
Check the MAF sensor and inspect the boot between the MAF and the engine for cracks.
Conversation Summary
The owner of a 1989 Trooper that had been sitting reports that after replacing the fuel pump the engine starts but only runs for a few seconds before dying, even though it will briefly rev with throttle. The owner suspects a fuel issue and asks whether injectors could cause it. The expert suggests the MAF sensor may be at fault and recommends checking for cracks in the boot between the MAF and the engine.
