1998 Isuzu Trooper Grinding Noise
1998 ISUZU
BOBRULES5
My 1998 Isuzu Trooper with 99,000 miles recently started making a loud metal on metal noise. It sounds like a someting spinning. It does not get louder or softer by acceleraton, but start loud and quiets a bit after a few seconds. Then as I drive a few minutes the noise seems to get louder.
I took it to a local repair shop hoping for the best and semi prepared for more. Much to my surprise they were able to find many things wrong.
Here is what I was told is wrong. The cause of the noise is the Air Conditioning compressor and all that comes with that. They said that since Isuzu runs on 1 belt?, it is important to repair. Cost $1389.00 w/labor. Then the water pump. Has a small leak. 680 w/labor. Then the rear calipars are locked (news to me) $1100.00 (pads rear and bac, which by the way both replaced in last 15 months). You see where I'm headed. 98 trooper - $3000 in repairs, I'm not sure it's worth it. The problem is i still owe a couple grand on the care and can't scrap it. I'm looking for advice. I plan on getting some sort of second opinion. Not so much because I don't believe them as much as i need a fix for cheaper! Any ideas???
J
Apr 13, 2006 at 1:29 PM
LOSONE
  • 1,616 POSTS
A lot of those repairs can be made with used parts. It doesn't take a brain surgeon to fix brakes and replace some of the other items. The compressor is easy to replace you have to have it charged. A lot of people get "upside down" in vehicles but it sounds like yours is worth saving with used parts. Good luck
Apr 14, 2006 at 3:40 AM
Suggested Repair
Get a second opinion and consider used parts to reduce cost. The AC compressor is relatively easy to replace but must be charged afterward; brakes and the other listed items can also be repaired with used parts. The vehicle may be worth saving rather than scrapping.
Conversation Summary
The owner of a 1998 Isuzu Trooper with 99,000 miles reports a loud metal-on-metal spinning noise that starts loud, quiets briefly, then grows louder while driving. A shop blamed the AC compressor at about $1,389 and also cited a leaking water pump and locked rear calipers, totaling about $3,000. The owner still owes money and wants a cheaper repair and a second opinion. The expert said used parts can lower the cost, brakes and related repairs are straightforward, the compressor is easy to replace but needs charging, and the vehicle is likely worth saving.
