No Starter Operation?
SERVICE WRITER
  • 9,123 POSTS
I'd be offended if you had an alternative answer and didn't speak up!
Thursday, September 3rd, 2020 AT 4:59 PM (Merged)
RHALL77
  • 3,361 POSTS
Thanks service writer. I just saw someone in the mod forum get mad about it.
JAYJAY11
I did put a charger on the battery and still nothing, I looked up in the haynes book and they said something about the bcm so I took it out and was going to take it to the dealer and see if they can test it. The security light will not go off no matter what it runs the battery down so I unhook the ground.
SERVICE WRITER
  • 9,123 POSTS
Did you try what rhall77 said first?
I'd be curious to learn if it can be bench tested.
So you are saying that the battery is at full charge and it does not crank?
IF so verify the battery is good and fully charged.
OR it cranks and does not start?
Anything been done to the ignition switch?
You might be stuck with having to have a shop that has a scanner capable of turning the security light on and off. If it doesn't a bad cluster may be present. And just the source of the drain.
I think I would treat it as a parasitic draw and see what circuit has the drain. "Google" testing a parasitic draw if you don't know how. When you find it, I think you'll find that fuse is the one on the same circuit of the security light.
Hey rhall77,
Anyone that gets upset about getting more help; makes me question their intentions of trying to help.
This is a comment from a site that is similiar to this one from a member ( I replace the site with XXX:
Thanx to everyone that did reply. XXX is better than ANY tool I have in my toolbox. Never under estimate the power of XXX to solve complex issues. There are so many knowledgable people out there that are more than willing to help and offer suggestions. XXX is priceless. Thanx XXX and all of it's members for sharing their knowledge to solve these issues. I'll be back regularly to offer my ideas to others.
RECCHIONE
  • 2001 CHEVROLET SILVERADO
  • 110,000 MILES
I don't know much about cars but I have a 2001 Chevy Silverado 1500 4.3 liter v6 engine that has a problem starting. When I turn the key the head unit and lights work but no sound from the engine. The battery is about 5 years old, don't know if that is the problem. Thought it was the starter at first so I took it up to Advance to get it tested and it works just fine. So I bought a new fuse for the starter relay and replaced it and it started working just fine for about two days. Now it is having the same problems as before but if I wiggle the fuse around it will sometimes start. Am I just in the complete wrong direction?
This guide can help us fix it
CRACRA
I have a 2001 Silverado 5.3 and it will not start sometimes. I turn the key and 9 out of 10 time it will start, but maybe twice a day I turn the key and nothing, finally after turning the key 50 or 60 times it will start just fine. The starter has been tested and is fine. I think there is a problem from the key to the starter, somewhere between. Does anyone know what that might be? Thanks
JDL
  • 16,098 POSTS
I'd make sure the battery cables/wires are clean and tight on both ends.
There should be a starter relay in the power distribution center, you can do some testing there, when the problem occurs. Just make sure the tranny is in park or neutral and the e-brake is set.
If this is an automatic tranny, have you tried cranking it in neutral, when the problem occurs?
MIXMAN1
  • V8
  • 70,000 MILES
Been running fine, won't even click this morning. Voltage good, fairly new battery, just wont start. Turned on the headlights, they are as bright as when it is running?
RHALL77
  • 3,361 POSTS
You will have to check for voltage at the starter solinoid. Also check and see if there is a fuse for the starter and see if that is good.
MIXMAN1
All the fuses are good, and I swapped the starter relay with one that I know is working. I don't have any way of checking the voltage at the solenoid. Are there any other steps I could take?
RHALL77
  • 3,361 POSTS
Not really you are gonna have to get a test light to see if you are getting power to the starter.
STEVEN HOLLAND
  • 5.3L
  • V8
  • 4WD
  • 262,000 MILES
This morning I brought my son to school, truck ran fine, stopped at the store on the way home and when I came back out it would not start. Plenty of battery power, no click nothing! I am assuming neutral safety switch but somebody told me to check the fuse first. Which fuse is it that I check? And where is it located?
STEVE W.
  • 15,276 POSTS
Try running the shift lever through the gears while holding the key on. Sometimes you can get the switch to work enough to get it started. Could also be a bad connection at the starter. Fuse 1 will be under the hood in the box and labeled Start the other one will be in the interior fuse box and labeled start/ign.
STEVEN HOLLAND
I will try that now! Thank you so much for the reply
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,217 POSTS
Please let us know what you find so it will help others.
Best, Ken
