fuel pump relay/fuse
HYUNDAI
TV1960
2000 hyundai elantra, mil 155,000, engine 1.8 litre, 5 speed manual transmission.
the fuel pump relay/fuse keeps going out in the fuse box under the hood, listed as the ECU. i have been unable to pin point the cause. any advice on resolving this would be appreciated. thanks :?:
Sep 29, 2007 at 2:52 PM
  • 31,937 POSTS
Hi there,
i would be checking the fuel pump, it sound like it may be loading up and causing the fuse fuse to blow, I would be checking pressure and flow rate to gauge the serviceability of the pump. also check all body earths as this may also be a cause.
Mark (mhpautos)
Sep 30, 2007 at 10:20 AM
