Hazzard lights and horn
HYUNDAI
CSAREL
1999 Hyundai Elantra wagon 42,000 4cyl
I turned on the hazzard switch and nothing, I checked the fuse and it was blown. I replaced the fused and it promptly blew. Relay?
Horn is very intermittant. Is it wise for me to pull the steering wheel with an air bag? ( I think it could be the contact on the steering wheel)
Thanks, csarel
csarel@cox.net.
Mar 15, 2007 at 3:00 PM
2CARPRO JACK
  • 11,533 POSTS
Could be the relay. Do all turn signals work ok? You can use a meter to test the wiring for a short to ground at the switch. Yes you can remove an air bag steering wheel, but you should follow all safety instructions when doing so.
Mar 16, 2007 at 1:00 AM
CSAREL
Yes, turn signals work fine, no issues there.
Perchance, do you know where the relay is ? Manual is no help.
Thanks for your prompt reply!
Tom
Mar 16, 2007 at 1:11 AM
CSAREL
bump
Mar 27, 2007 at 3:02 PM
