2001 Hyundai Elantra Brake Lights Stay On Fix
HYUNDAI
NOTTICK
2001 Hyundai Elantra / 31000 miles.
brake lights won't go off :(
Other than disconnecting my battery to avoid it draining, what should I do?
Thanks in advance for any replies
Dec 9, 2006 at 1:02 PM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the problem may be the brake light switch. Sometimes the switch is adjustable am\nd may just need to be readjusted. If it is not the adjustment then the switch may be defected. It is located on the brake pedal under the dash. Good luck. Backyardmechanic :)
Dec 10, 2006 at 2:51 AM
NOTTICK
It was in fact related to the switch. On the break pedal shaft there was a white plastic washer which makes contact with the swith. That washer had fallen off.
I replaced it with a bumper stop, total cost 85 cents.
Thanks!
Jan 2, 2007 at 1:56 AM
BACKYARDMECHANIC
  • 337 POSTS
Glad to Help. Have a Happy New Year
Jan 2, 2007 at 10:29 AM
Suggested Repair
Check the brake light switch on the brake pedal under the dash. The white plastic washer or bumper that contacts the switch can fall off and leave the lights on; reinstall or replace it, or adjust or replace the switch if needed.
Conversation Summary
The owner of a 2001 Hyundai Elantra reported brake lights that stayed on and was concerned about battery drain. An expert suggested the brake light switch under the dash might need adjustment or replacement. The owner found that a white plastic washer on the brake pedal shaft that contacts the switch had fallen off and replaced it with an inexpensive bumper stop, which fixed the problem.
