1997 Hyundai Elantra A/C Not Cooling
HENRYD315
  • 13 POSTS
I have a 1997 hyndai Elantra 4 cyl milage is 172000 My A/C sytem is not cooling I checked the refrigerent level with a over the counter $9.00 gauge for checking refrigerant level the gauge reads in the blue fully charged I then checked the blend door and this was also operating properly it was opening and closing also my compressor turns on immidietly after pushing the A/C switch, the low pressure aluminum hose is very cold at the engine entering the engine firewall can you help me narrow down my problem and my vehicle does have 2 fans at the radiator how do I know which one is for the A/C system I would appreciate your guidance.
Thank you :?
Apr 3, 2006 at 9:04 AM
LOSONE
  • 1,616 POSTS
The smaller fan is the condenser fan. It should come on when the compressor engages. If it doesn't you will have high head pressure and and cool not cold air.
You might have a blend door problem letting in heat as a mix.
Apr 3, 2006 at 11:28 AM
HENRYD315
  • 13 POSTS
Thank you very much for your assistance I located the problem it was the blend door ,the blend door cable was not closing the door completely and it was as you said mixing hot air with cold air I followed the red and blue air temp knob and located the cable I then manually adjusted the cable as instructed in my Chiltons repair manual #32102 page 6-21 my wife will now give me my truck back :D :lol: 8) 8) 8) 8)
Apr 4, 2006 at 4:32 AM
Suggested Repair
Adjust the blend door cable so the blend door closes fully and does not mix hot air with cold air. Also confirm the smaller condenser fan comes on when the compressor engages.
Conversation Summary
The owner of a 1997 Hyundai Elantra reported that the A/C was not cooling despite a full refrigerant reading, a working blend door, and a compressor that engaged immediately. The low-pressure hose was very cold, and the owner asked which of the two radiator fans served the A/C. The expert identified the smaller fan as the condenser fan and said it should run with the compressor, otherwise head pressure would be high and the air only cool. The expert also suggested a blend door might be mixing in heat. The owner later confirmed the blend door cable was not closing the door completely and adjusted it using a Chilton manual, which resolved the mixed hot and cold air.
