1999 Hyundai Elantra Reverse Light Stuck On
HYUNDAI
96761UTI
my 1999 hyundai elantra reverse light wont turn off anytime car is koeo/koer. dont know where it is getting power from?(car is standard)
May 23, 2007 at 8:10 PM
GARFIELD
  • 197 POSTS
It sounds like your Reverse/back up switch has failed in the closed position.
May 23, 2007 at 10:37 PM
TURBOTUFF20G
  • 98 POSTS
the reverse switch mounted ontop of trans is the culprit, these always go bad,, have to do some digging to get to but it is easy do it your selfer, i think the sensor is a 19mm
May 27, 2007 at 11:54 AM
Suggested Repair
Replace the reverse/backup light switch on top of the transmission. It is likely failed in the closed position, keeping the lights on with the key on. Access takes some work, but it is a DIY repair; the sensor is about 19mm.
Conversation Summary
The owner of a 1999 Hyundai Elantra with a manual transmission says the reverse lights stay on whenever the key is on and asks where the power is coming from. An expert says the reverse/backup switch has failed closed. A follow-up confirms the switch on top of the transmission is the usual failure, is reachable with some digging, and is about 19mm.
