2000 Hyundai Elantra Fuel Pump Fuse Blows
HYUNDAI
TV1960
2000 hyundai elantra, mil 155,000, engine 1.8 litre, 5 speed manual transmission.
the fuel pump relay/fuse keeps going out in the fuse box under the hood, listed as the ECU. i have been unable to pin point the cause. any advice on resolving this would be appreciated. thanks :?:
Sep 29, 2007 at 2:52 PM
  • 31,937 POSTS
Hi there,
i would be checking the fuel pump, it sound like it may be loading up and causing the fuse fuse to blow, I would be checking pressure and flow rate to gauge the serviceability of the pump. also check all body earths as this may also be a cause.
Mark (mhpautos)
Sep 30, 2007 at 10:20 AM
Suggested Repair
Check the fuel pump for excessive load by testing fuel pressure and flow rate. Also inspect all body grounds, which can cause the under-hood ECU/fuel pump fuse to blow.
Conversation Summary
The owner of a 2000 Hyundai Elantra with a 1.8L engine and manual transmission reports that the under-hood fuel pump relay/fuse, listed as the ECU, keeps blowing and the cause has not been found. The expert suggests the fuel pump may be drawing too much current and recommends checking fuel pressure and flow rate, plus all body grounds.
