2001 Hyundai Sonata Bucks and Stalls
HYUNDAI
CHARLENE24
2001 hyundai sonata 115,000 miles. when im driving my car the speed drops to like 20 the rpm just keeps jumping, my car bucks to where it kills im not sure if its the fuel pump or the fuel pump relay.
Oct 8, 2007 at 5:00 AM
  • 75,988 POSTS
To find out for sure if its coming from the fuel system-you need to check the actual fuel pressure with and with out the pressure regulator then comeback, we got a long way to go this is just the beginning of it.
Oct 8, 2007 at 5:55 AM
Suggested Repair
Check actual fuel pressure with and without the pressure regulator to see whether the bucking and stalling is fuel-system related before replacing the pump or relay.
Conversation Summary
The owner of a 2001 Hyundai Sonata with 115,000 miles reports that while driving the speed drops, RPM jumps, and the car bucks until it stalls, and suspects the fuel pump or fuel pump relay. The expert says to confirm a fuel-system problem by checking fuel pressure with and without the pressure regulator, noting that further diagnosis will still be needed.
