2002 Hyundai Sonata Fuel Pump No Power
2002 HYUNDAI
MANXDUDE
2002 sonata 71,534 miles 4 cyl auto trans
I just posted a question reguarding the timing belt I was still testing things on it and I pulled back the carpet in the trunk and traced the wires to what I believe is the fuel pump,(there is a black access door with wires going through it) when I test the wires I don't get a signal on any one of them, key on and off. I checked the fuse under the hood and its good, where do I go from here?
Thanks
Oct 4, 2007 at 1:47 AM
  • 75,988 POSTS
First try directing power to it from the battery to the pump and see whether it will come On. If not replace it. Now for the power-the fuel pump relay only comes on for 2 sec then quit at starting position it will have power-do this No go. check the fuel pump relay
Oct 4, 2007 at 3:24 AM
Suggested Repair
Apply battery power directly to the fuel pump and replace the pump if it does not run. If it does run, check the fuel pump relay, noting that the relay powers the pump for only about two seconds and again during cranking.
Conversation Summary
The owner of a 2002 Hyundai Sonata with 71,534 miles said it quit running while checking the timing belt. No voltage was found at the suspected fuel-pump wires behind the trunk access panel with the key on or off, and the under-hood fuse tested good. The expert advised powering the pump directly from the battery and replacing it if it does not run, then checking the fuel pump relay if direct power works.
