2002 Hyundai Sonata Fuel Filter Location Fix
HYUNDAI
BOSSMAN
i have a 2002 hyundai sonata 84000k/m 2.4L could you let me know
where is the fuel filter located
Mar 7, 2007 at 11:19 AM
BRUCE HUNT
  • 3,754 POSTS
Take off the back seat bottom cushion. Then remove the fuel tank sender cover. Take off the gas cap where you fill the tank to releive pressure. Then remove the ground wire and take off the fuel lines from the filter.
Mar 8, 2007 at 8:28 AM
Suggested Repair
Access the fuel filter under the rear seat. Remove the bottom cushion and fuel tank sender cover, remove the gas cap to relieve pressure, then disconnect the ground wire and fuel lines from the filter.
Conversation Summary
The owner of a 2002 Hyundai Sonata 2.4L asked where the fuel filter is located. The expert said it is reached under the rear seat by removing the bottom cushion and sender cover, relieving pressure at the gas cap, and disconnecting the ground wire and fuel lines.
