2002 Hyundai Sonata Slow Fuel Fill
HYUNDAI
DHIMES
I have a 2002 Hyundai Sonota LX, 98,000 miles, 6 cyl., 3.0 liter engine. For the past 2 weeks I have not been able to add fuel to the tank without the pump shutting of every 20 or 30 seconds. I know the tank is not full because if I perservere and stand there for 15 minutes or so, I can finally get 13 -15 gallons to fill the tank. This happens at any service station I have tried. The pump keeps shutting off every 20-30 seconds while pumping fuel as if the fuel is backing up to the filler tube .
Oct 2, 2007 at 1:39 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like some kind of restriction/venting problem in the filler tube.Didnt see any TSB's (tech service bulletin) regarding that problem. Might want to have a shop look at it, doesnt sound dangerous, just annoying. BTW did this just start all of the sudden or the entire time you have had the car?
Oct 3, 2007 at 12:44 AM
DHIMES
I bought the car new in Sept. 02 and it just developed this problem about 10-14 days ago. There were no indications of any problem prior to that nor was there any contributing incident. I just stopped to gas up one day about 2 weeks ago, and the problem started.
Oct 3, 2007 at 9:21 AM
2CARPRO JACK
  • 11,533 POSTS
Might want to have a shop look at it just in case the tank needs to be lowered or removed to fix it
Oct 3, 2007 at 9:22 AM
Suggested Repair
Have a shop inspect the filler tube for a restriction or venting problem. The fuel tank may need to be lowered or removed to correct it.
Conversation Summary
The owner of a 2002 Hyundai Sonata LX cannot add fuel without the pump nozzle shutting off every 20-30 seconds, although the tank is not full and 13-15 gallons can eventually be added. The problem began suddenly about two weeks earlier and occurs at every station. The expert suspects a filler-tube restriction or venting issue, found no related technical service bulletin, and recommends a shop inspection, possibly requiring the tank to be lowered or removed.
