2000 Hyundai fuel tank
2000 HYUNDAI
99,600 MILES • 4 CYL • 2WD • AUTOMATIC
FRANKMETZ
When I go to fill up my tank 87 oct. the gas station fuel pump will stop every 1/10 of a gallon.
I tryed diffrent fuel pumps and as well diffrent gas stations with 87 89 93 oct. It will always stop me from pumping fuel fast. What could the problem may be? thank you
Dec 9, 2007 at 9:55 AM
BLACKOP555
  • 10,386 POSTS
you didnt hook it up right. The brake safety switch will not let you change it out of gear unless hte pedal is pushed and since it isnt hooked up right it wont let you move it.
Oct 19, 2007 at 9:10 AM
DANNETTENM
[quote:4846e0439f="dannettenm"]I have a 2002 Ford Ranger xlt. The Break lights has stopped working. So i took it in to get checked and they told me to just change the on and off light switch on the break pedal and he told me how to do it and said it was easy and that i could do it myself, Well i did and it was easy but now the gear won't shift out of park and the break lights still don't work... so my question is what else could be wrong ?[/quote:4846e0439f]......................
Ok thanks... well i went back and fixed it and my break lights were working. They worked for a little while and now it's off again, it's not working anymore... could it be another problem? or should i just buy another switch and do it again?
Oct 23, 2007 at 1:18 AM
BLACKOP555
  • 10,386 POSTS
Try another switch if that goes out you may have a shorting wire somewhere.
Oct 23, 2007 at 1:52 AM
KIPPERSNIPPER
The same thing happens to me when I fill up my 2000 Elantra. I thought that it was actually the gas station pumps at first, until I noticed that it happened everywhere I went. So I called Hyundai USA at 800-633-5151 to see if there were any recalls on the problem, but there wasn't any. They gave me a case number, and I think that if they get enough phone calls, they will recall the item. All they could tell me is to take it in to the dealer to get it checked. Make sure you have your VIN when you call.
Jan 30, 2008 at 4:20 AM
